Question / Help AMD DRIVE PROBLEN IN GAMES CRASHING
alexandercupo
hi SOMEONE TOLD ME HIS PROBLEM SOLVED HERE i have problem in amd graphice drive its when i play game(assassins creed ody or orgins or other game ) its crash its was working good before but when i open power options >change plan settings >change advanced power settings >AMD graphics power settings > AMD powerplay settings >plugged in (make it maximize battery life ) game working good but low performance and when make it *(maximize performance ) game crashing from beging please help on that and i setup alot of new windows 10 and 8.1 and same problem i upgrade graphics card for last drive and same problem deleted all programes and same kindly support me thx
This is a support forum for OBS Studio, a streaming and recording software. Not a forum to discuss general PC or game crashes. If you use OBS Studio, and you have an issue with OBS Studio, this is the right place to post. If you don't have an issue with OBS Studio, this is the wrong place to post.
sry but someone told me he get solved here sry agine
