atkAudio Plugin
atkAudio Plugin 0.32.3
atkAudio
Dear @atkAudio:
Hope this message finds you well... I'm unable to use the plugin, and I suspect that it might be because I'm using a portable version of OBS that isn't installed in the typical Windows location. However, I'm not sure.
I executed the included installer, and I noticed that C:\ProgramData\obs-studio\plugins\ is selected as the default install location. I OK'd my way through the installer without making any changes to the same. However, when I run my OBS Studio, I'm unable to locate or use the plugin. I also tried copying the bin and data folders that I found within the aforementioned installation directory into my OBS install location, but that doesn't seem to work either.
Any guidance would be greatly appreciated. Thanks in advance.
-Alex
Dear @atkAudio:
-Alex
Copying the atkaudio dll files from C:\ProgramData\obs-studio\plugins\atkaudio-pluginforobs\bin\64bit into your OBS install plugin directory (e.g. C:\obs-studio-portable-install\obs-plugins\64bit) should do it.
Dear @atkAudio:
-Alex
Does the plugin installer depend on registry entries or a standard OBS path? If so, how can I manually integrate the plugin with a portable setup? I’ve already tried copying the bin and data folders into my OBS directory, but it still doesn’t show.
Am I correct in thinking that this plugin brings all things related to the OS audio functions _into_ the OBS interface, pluse plugin management and use?
dont copy the directory structure, just copy the .dll files into your portable installation plugin directory
That worked! Thanks :)
This worked for me
