Breakpoint Error 0x8000003 | Need Sollution - Urgent
ThunderBoyArun
I only know that the error after the Elgato Installation. OBS Studio works only for 15-20 minutes with Elgato Video Capture, but it works perfectly with Laptop Display Capture.
Error Message: Breakpoint Reached,
Error Code 0x8000003 occured in the application location 0x00007FFE0BAF3542.
My Laptop Specs:
Lenovo IdeaPad Gaming 3 15IMH05Q(Model 81Y4)
Intel i7 -10750H (2.60GHz)
8GB RAM
4GB Nvidia GeForce GTX 1650
And I also have an another issue with OBS & Streamlabs, that sometimes Webcam automatically switching off. For this, I have to deactivate & activate the camera everytime when it's off.
Please restart OBS and perform a test stream/recording for more than 30 seconds doing as you normally do, including playing games, full camera or whatever you normally do.
Now look inside Help menu. Upload the current log file and paste the url to the log in here. You can also check for previous logs, specially the one when the crash happens and you can attach it (button bellow)
Do the same with the crash repost that should be created. Again, inside help menu you can access to it.
This is the first crash log file, the obs saved https://obsproject.com/logs/d2WQZ5Y8ROkFiJNC
The crash is in a browser source or dock.
Anyway, the main issue:
You're using SE.live. Please contact them for support.
Alternatively, uninstall it. Then uninstall and reinstall OBS in order to fix the changes made by SE.live. Now please do a test stream/recording of more than 30 seconds and post the log file here.
You also can (or should) remove the remaining se.live files from the %appdata%\obs-studio folder.
It doesn't work at all
