Broken audio when playing pre recorded videos
Clum
Hello,
I'm doing some testing for a concert that I'm broadcasting in a few weeks that involves pre-recorded videos being played.
The issue is with the pre-recorded videos, the audio is utterly broken when they're played and I can't for the life of me work out why.
Here's a link because I'm unable to upload an example: https://youtu.be/d2Goh4dzTwc
I've attached my audio settings as well as my various logs.
Thanks in advance!
  • 2020-11-13 09-19-12.txt
  • 2020-11-13 10-00-33.txt
  • 2020-11-13 10-34-42.txt
  • 2020-11-13 10-59-09.txt
  • 2020-11-13 11-45-39.txt
  • 2020-11-13 11-52-26.txt
  • 2020-11-13 12-54-18.txt
  • 2020-11-13 13-59-03.txt
Have you tried the following (yes, I know this shouldn't be necessary)
In advance of streaming/recording, Go thru your scenes/sources and play all Media Sources (at least start them, maybe skip thru them quickly (if you are using Media Controls plug-in)
- now try again...
I, too ran into the issue of the pre-recorded video file being just fine. But the first time after opening OBS and playing each video, a portion of them would glitch at the beginning. Pre-playing fixed issue. This was on fast computer, with fast SSD (but possible corporate security s/w causing problem) ... so... anyway, the work-around I used.
