Camera and Audio Works when Alt-Tabbed from a game, but Stutter when in-game, even if the game is still running on the background.
SetArk
Well i just discovered this today.Was planning on starting the year playing BG3 but, for some reason, my camera just refuses to work.The game can be running on the background, animations, fights, everything, if alt tabbed, the Webcam works perfectly.But when i alt tab back into the game, webcam just won't work.
It'll stay laggy as fuck.
Apparently even my voice gets choppy from time to time, with or without NVidia Broadcast. I tested with it on and with it off.
Don't know what could be.
Even tried putting the game on lower settings and it kept happening.
Any ideas of what could be causing it?
Win 10 Latest.
Antivurs is Malwarebytes Free + Windows Defender.
OBS is using Game Capture because Window Capture have that dumb yellow border.
Specs:
RTX 3050
I9-9900k
16GB RAM 3000hz
Everything running on a NVME SSD
Only one tab of Chrome to use my stream manager.
All the rest dedicated to the streaming setup.
In the past i've streamed on this exact setup BG3 and well, camera worked fine. Well only change is the new Mic i guess and new Window install.
Everything is opened as running through Administrator
Apparently, this is the Log from my previous stream.
https://obsproject.com/logs/EektsE9D4w0TeWju
So.. Somehow my audio is the problem?
Dafuck?
https://www.reddit.com/r/obs/comments/1914w86/camera_works_when_alttabbed_from_a_game_lags/
Again the game is running perfect, no stutters.
