Easy Backup and Delay
Easy Backup and Delay 1.7.5
miguelangelcsgo
miguelangelcsgo submitted a new resource:
EasyBackupandDelay - Never lose your scenes again — 1-click backup/restore, plus broadcast delay tools for streamers.
EasyBackupandDelay
Your whole OBS setup, safe in one click — and pro broadcast‑delay tools built for streamers.
Ever spent hours perfecting your scenes… then lost them to a crash, a corrupted profile, or a new PC? EasyBackupandDelay makes that impossible. And while we were at it, we added the broadcast‑delay toolkit competitive streamers have been asking for.
1‑Click Backup & Restore
  • Back up...
If you create a side plugin for ONLY the delay feature, it will be a massive one for FPS streamers who want Delay when playing (for the game, mic and camera) and then Live when chatting! Is this possible?
being able to have a whole scene delayed in another scene (so scene in a scene) would be great
This plugin already does that. If you want, stop by my stream when I'm live, and I'll show you how to do it. Cheers!
Ahh okay! I think time is hard as I am on the other side of the world - perhaps a recorded demo if possible? It would allow users who click on the plugin to see how it works immediately.
I also tried adding the Video Filter to a scene, and the Audio Filter to a few audio inputs. However when the filter is on, it doesn't seem to delay?
miguelangelcsgo updated Easy Backup and Delay with a new update entry:
v1.8.1 — OBS 32.2+ compatibility fix
v1.8.1 — Compatibility update
Fixes loading on OBS Studio 32.2.x. OBS 32.2 shipped a newer FFmpeg (avcodec 62 / avutil 60 / swscale 9); the plugin was rebuilt against it, so it loads again instead of failing silently on startup.
  • Fixed: plugin not loading on OBS 32.2.2 ("module not loaded", LoadLibrary error 126) due to the FFmpeg version bump.
  • No feature or settings changes — your backups, delays and Web/Stream boxes work exactly as before...
EasyBackupandDelay 1.9.0
v1.9.0
Everything that landed since 1.7.5.
New in 1.9.0
  • Sources that follow the delay switch — each source can be set to "show while the delay is ON" or "show while the delay is OFF", and the plugin shows or hides it automatically, in every scene it appears in. Typical use: a full-screen capture that is only visible without delay, and a game-only capture that is only visible with delay — the same delay key swaps them...
I never saw one, either. In fact, being a plugin, I think there's even a requirement for the source code to be available under the GNU GPL 2.0+ (OBS Studio itself uses the GNU GPL 2.0) per one of the newest stickied threads at the very top of this forum. In fact, it's the very first requirement.
--Katt. =^.^=
Yeah I do believe source code is supposed to be public too haha
Not necessarily public. Just available under the GNU GPL 2.0 or later. That said, being public is the best way to verify that it is available.
--Katt. =^.^=
Yeah - tbh the backup feature is not something I'll use, and maybe a lot of others.
The big ticket item in this plugin is the Delay feature for Video and Audio. Any FPS streamer (CS/Valorant) will use that for live delay and turn it off after the game to talk to chat instantly.
A turn off is the fact that the Mic beeps at you in your ears when it plays back what you said X seconds later. Its also a bit clunky that I can turn the filter eye on, and the delay is not actually on and delaying unless I press the hotkey or the button on the dock.
If its changed so that for the delay, eye filter on = delay is on (or the delay buffer is building) - this would be best change and skyrocket the use of the plugin.
