Elgato Stream Deck help
hoffsiderunner
Hi!
i have an idea but im not sure how or if its possible.
i want to use my stream deck to change a text source in OBS. if I have a text source with a number and then I press a key on the stream deck and it adds +1 to that number. like a scoreboard, I score a goal presses the key and it adds +1 to that scoreboard.
Anyone know if this I possible?
Thank you.
Hey. I think this is what you need.
Stream Deck -> More Actions... -> Stream Counter -> Install ...
