Question / Help Frame rate drop with dual stream PC and 2 HDMI cables
FreeRide23
Hi there,
i have a Problem with frame rate at main monitor (Display Port), if i use a second Monitor (HDMI) and
a Streaming card (HDMI) at the same time.
The games get so laggy, so "slowed" that i get headache in like 10 minutes...
As far as i found out, i think its about the frame rate of each monitor, the primary one (iiyama G-Master GB2730HSU-B1 Black Hawk, 27") got 30-84kHz (horizontal), 40-75Hz (vertikal)
and the second one (LS23C350HS/ZA) got like 50-60.
The "anoying" part is, that if i plug in the streaming card (avermedia Live streamer HD 2) and i "deactivate" the second one,
it is still happening, so i would have to unplug it manually, to not get the frame drops, what is quite shit (crawl down the table, etc.).
The Capture card is plugged into an second computer (streaming PC).
I use OBS to stream to second PC and then capture there with an other OBS the game.
So my question is, can i solve the problem with "software" adjust any frames, settings, drivers, etc, or must i buy an other HDMI cable, other monitor (i think this will be the solution, rofl), or what u think???
So here are my equipment and all my settings, if u have any other questions, pls respond here or to my email Claus.W@gmx.net
Win7 x64 Pro (up to date)
Radeon RX 580
LS23C350HS/ZA
Avermedia Live Streamer HD 2
Tryed different HDMI cables, some work on one monitor, some on the other
Graphics Card:
Radeon Softwareversion - 19.1.1
Radeon Software Edition - Adrenalin 2019
Grafik-Chipsatz - Radeon RX 580 Series
Speichergröße - 8192 MB
Speichertyp - GDDR5
Kerntaktung - 1366 MHz
Windows-Version - Windows 7 (Service Pack 1) (64 bit)
Systemspeicher - 16 GB
CPU-Typ - Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
Version der Radeon Einstellungen - 2019.0109.1906.34385
Versionshinweise anzeigen - https://www.amd.com/en/support/kb/release-notes/rn-rad-win-19-1-1
Treiber-Paketversion - 18.50.11.01-190109a-338125C-RadeonSoftwareAdrenalin2019
Anbieter - Advanced Micro Devices, Inc.
2D-Treiberversion - 8.1.1.1634
Direct3D® Version - 9.14.10.01377
OpenGL® Version - 25.20.15000.13544
OpenCL™ Version - 25.20.15011.1004
AMD Audio-Treiberversion - 7.12.0.7728
Vulkan™ Driver Version - 2.0.68
Vulkan™ API Version - 1.1.96
Grafikkarten-Hersteller - Powered by AMD
Geräte-ID - 67DF
Anbieter-ID - 1002
Subsystem-ID - 3418
Subsystem-Anbieter-ID - 1462
Revisions-ID - E7
Bustyp - PCI Express 3.0
Aktuelle Buseinstellungen - PCI Express 3.0 x16
BIOS-Version - 015.050.002.001
BIOS-Teilenummer - BK-AMD VER015.050.002.001.000000
BIOS-Datum - 2017/11/13 21:41
Speichertyp - GDDR5
Speichertaktrate - 2000 MHz
Gesamte Speicherbandbreite - 256 GByte/s
Speicherbitrate - 8.00 Gbps
2D-Treiberpfad - /REGISTRY/MACHINE/SYSTEM/CurrentControlSet/Control/Class/{4d36e968-e325-11ce-bfc1-08002be10318}/0003
OpenGL® API Version - 4.6
OpenCL™ API Version - 2.0
1 Monitor:
Horizontales Timing gesamt - 2200
Horizontales Timing Anzeige - 1920
Horizontales Timing Front Porch - 88
Horizontales Timing Sync-Breite - 44
Vertikales Timing gesamt - 1125
Vertikales Timing Anzeige - 1080
Vertikales Timing Front Porch - 4
Vertikales Timing Sync-Breite - 5
Horizontales Timing Polarität - Positive
Vertikales Timing Polarität - Positive
Interlaced/Progressiv - Progressive
G. Pixeltaktrate (kHz) - 148350
G. Wiederholfrequenz (Hz) - 59.9394
Aktueller HDCP-Status - Disabled
Aktuelle Link-Einstellungen - 1.62 Gbps x 4
2 Monitor:
Aktueller HDCP-Status - Enabled
Aktuelle Link-Einstellungen - Not Available
