Halsu plugins for streaming
Halsu plugins for streaming 1.1.1 (20260209)
Eki Halkka
Eki Halkka submitted a new resource:
Halsu plugins for streaming - A collection of compositing tools for OBS
Halsu plugins for streaming is a collection of third-party plugins for OBS Studio, focused on live compositing, chroma keying, alpha-matte cleanup, and edge integration.
The plugins are designed to work out of the box with sensible defaults, making them usable for beginners, while still exposing advanced controls for users who need deeper control over keying and compositing behavior.
Included plugins:
Halsu...
Looks good. Mac version soon?
Unfortunately, i do not have a Mac and that's probably not changing in near future at least - which means, testing and fixing bugs on Mac is practically a no go for me. Tried too do some of that with a shaderfilter version of the keyer earlier, was really nearly impossible, because every change-test-change loop took days, sending files back and forth with a Mac user.
This said, the plugins are open source, so any Mac developer could likely port these quite easily.
Thank you for your quick reply and your attempts with a Mac user. One thought is can you try a virtual mac on your pc? I have virtual Window on my Mac which lets me try OBS software that isn't working properly on my mac. It's not practical though, because I do everything on my mac and I'm not sure if I can get the same quality as my mac. Well, at least I'll be able to play around with your plugin. Thanks.
Hi, im having issues implementing the plugin to my obs. I did just how the readme said and I extracted and added all the files to the correct folders ( I double-triple checked lol) but for some reason the effects (like relightwrap) dont appear on my filter list. I checked the plugin manager and the log report but neither are able to find anything about your halsu plugins. I already have a few plugins in my obs and they are in the same folders, same file type, everything and work without issue. I really dont know what to do to fix this so any kind of help would be really appreciated :)
Edit: I also tried restarting and running obs as admin. Also idk if its just me but the Download link for the zip file leads to a 404 on github, had to download and extract it through the source code
