Live Background Removal Lite
Live Background Removal Lite 4.0.1
umireon
umireon submitted a new resource:
Live Background Removal Lite - Removing the background from your video in real-time, without the need for a green screen.
An OBS plugin that allows you to remove the background from your video source in real-time, without the need for a green screen.
## Demo
## Features
* **No Green Screen Required:** Removes the background from your webcam feed without needing a physical green screen.
* **Simple & Easy to Use:** Just add it as a filter to your source, and you're ready to go. No complex configuration is needed.
* **Lightweight Performance:** Designed to be light on system...
umireon updated Live Background Removal Lite with a new update entry:
Relase 1.8.0!
Live Background Removal Lite v1.8.0​
Welcome to a fresh update! This release brings you a smoother experience, especially for web documentation and plugin integration.
✨ What’s New​
  • Web & Docs Polish:
    • The documentation site now features new icons and a web app manifest!
      (Look for apple-touch-icon, favicon, SVG icon, and maskable web app icons.)
    • Improved site metadata and PWA support for a more professional and...
Live Background Removal Lite v1.8.1
This is a quick maintenance update with improvements for Linux packaging and workflow automation!​
What’s Updated​
  • Arch Linux PKGBUILD:
    • The plugin now correctly declares curl as a dependency for both regular and -git packages.
    • Updated version numbers and checksums for smoother builds.
  • Flatpak Manifest Updates:
    • Flatpak build and metainfo files now point to the correct version and...
1.8.2
Live Background Removal Lite v1.8.2​
Welcome to version 1.8.2! This update brings internal improvements and some refactoring to make the plugin smoother and more maintainable.
What’s Improved​
  • Refactored Plugin Properties: The plugin’s settings and runtime properties are now handled more cleanly, making it easier to adjust filtering and segmentation features.
  • Debug Window Overhaul: The Debug Window now uses atomic...
1.8.3
# Live Background Removal Lite v1.8.3
This update is all about making the plugin easier to build and package, especially on Linux distributions!
## What’s New
- **Flexible Dependency Handling (CMake):**
- You can now build the plugin using `pkg-config` to find dependencies (curl, fmt, ncnn) instead of relying on CMake configs.
- Just set `-DUSE_PKGCONFIG=ON` when building via CMake to let it use system libraries—great for packagers!
- **Arch & Flatpak Packaging:**
- Arch PKGBUILD...
1.8.4
This release brings quality-of-life improvements for contributors, maintainers, and users!
✨ What's New​
  • GitHub Issue Templates:
    • Brand new issue forms for bug reports and feature requests!
      Now it's easier to submit clear, helpful feedback and ideas.
  • Automated Stale Issue Management:
    • Added a workflow to automatically mark and close stale issues and pull requests.
      This keeps the repository organized and encourages...
1.8.5
This is a quick improvement release to help plugin settings work more reliably!
What's Fixed & Improved​
  • Real-Time Settings Update:
    • When you change plugin properties in OBS, the internal settings are now instantly updated in the rendering context.
    • This helps ensure your changes to filter controls take effect right away—no more confusion or lag!
  • Packaging Sync:
    • Flatpak and Arch Linux packaging files updated for...
1.8.6
Live Background Removal Lite v1.8.6​
This update brings improved reliability, better property handling, and even more Linux compatibility!
✨ What's New​
  • Plugin Properties Refactored & More Robust:
    • Internal handling of plugin filter properties (like mask bounds, gamma, guided filter epsilon, and FPS) is now more robust and streamlined.
    • Default values and property updates are clearer and safer—making settings less...
1.8.7
Live Background Removal Lite v1.8.7​
This release is all about making your build experience smoother and more reliable, especially if you're using Arch Linux or Flatpak!
️ Build Stability Improvements​
  • Arch Linux & Flatpak Build Fixes:
    • Several tweaks to the build scripts and packaging manifests help ensure smoother, more predictable builds on Arch Linux and Flatpak.
    • Dependency handling is improved to avoid common...
Just a FYI: I downloaded the last upgrade today 10.11.25. for Mac OS Ventura (latest version), OBS 32.0.1 and the screen went black. Not sure how to downgrade unless you have a fix. Thanks. Update: I turned the source off and on then the screen is chroma keyed with me in front. but the control don't do anything. Thanks.
2.0.0 - GPU Available!
Live Background Removal Lite v2.0.0​
Welcome to the next major version! This release brings a breakthrough feature for users seeking even faster and smoother background removal: GPU inference support.
✨ What's New in 2.0.0​
  • GPU Inference Option (Vulkan/NCNN):
    • You can now leverage your GPU for real-time background removal, dramatically speeding up matte computation and reducing CPU load.
    • Easily select your...
This bug is already known and should be fixed in 2.0.0!
2.0.1 - GPU build fixed!
️ Live Background Removal Lite v2.0.1​
This is a quick bugfix release focused on making GPU acceleration easier to build—especially on Arch Linux!
What's Fixed​
  • GPU Build Reliability:
    • Fixed build issues that affected enabling GPU acceleration (Vulkan/NCNN) on Arch Linux and some other platforms.
    • Improved detection and linking of GPU dependencies, so you can select your GPU in the plugin without build headaches.
2.1.0 - Temporal stability and fixing major bug!
✨ Live Background Removal Lite v2.1.0​
This update brings both exciting new features and critical bug fixes for a smoother streaming experience!
What's New​
  • Temporal Stability Filter:
    • Introducing a brand new filter to stabilize your background removal matte over time!
    • This helps reduce flickering and jitter in your video, especially under challenging lighting or fast movement.
    • Enjoy a more natural and steady look...
I have identified the bug you mention, which occurs on filter addition, and fixed it at 2.1.0. I'm now confident that this plugin works well from the first time.
Sorry, my OBS friend. It still comes up a black screen. However, I appreciate that you include in the plugin to let me know it is up to date. Update: It works now, but if I try to adjust one of the sliders it would close OBS. Now it doesn't hm.... it did that twice after a restart twice. I'll keep you posted, I just downloaded the latest OBS 32.0.1., so this might be a factor.Thanks for all you do.
2.1.1 - Flatpak fixed!
This is a maintenance release that focuses on improving Flatpak support!
  • Flatpak Build Fixes:
    • Critical issues with the Flatpak build have been resolved.
    • You can now build, package, and run Live Background Removal Lite via Flatpak without unexpected errors or missing dependencies.
  • Better Packaging Experience:
    • Updates ensure smoother installation and compatibility for Flatpak users...
2.2.0 - Smaller landscape model!
This release focuses on performance and efficiency with a major update to the segmentation model!
What's New​
  • Smaller Segmentation Model Adopted:
    • The plugin now uses a compact and lightweight AI model for background segmentation.
    • Expect faster startup times and lower memory usage—especially helpful for laptops and lower-powered systems.
    • The new model maintains high segmentation accuracy while being easier on your hardware.
Thank You for your work on this plug in, however, it tells me I can upgrade, but I have. I've even manually deleted it for the new one to install. I am using a Mac if that helps. I'm grateful for this notification. so please continue with it. Thanks. Update: I looked at the date and version no. of this plugin after it was installed and it is up to date. Thanks.
