Lossless recording troubles
Im trying to record lossless but theres this color issue im running into.
Ik its an encoding issue more than an OBS one but not sure where else to go for this.
Currently I have it set up like this:
I changed it to libx264RGB for the RGB example
I changed it to RGB and full for the rgb example
The original is just a smooth gradient, I444 induces weird color banding, and RGB makes it too dark on the top
The difference between original and RGB is tiny but it's very much there
