If at all possible, don't. Even cheap USB is better. BT mics are pretty much designed for phone calls, and not much more.How to use 44.1KHz on OBS with BT microphone? I do not have audio input on my Intel NUC.
Bluetooth *anything*, really, is often a bad idea.
And wireless in general is much more of a liability than a wire is, even if you get a "professional" wireless mic or in-ear monitor that runs at a different radio frequency. There's just no way to *guarantee* that something won't interfere with it.
Right so I also made an account to give you a thanks. You should be proud of how much you've driven OBS Studio forum user registration!Hey, (in windows 11) you can fix this, by going to setting/system/sound/input/"BLUETOOTH_MICROPHONE" (Click The ">" in the right side) - Chose "Do NOT allow windows to use this microphone/input device" - After that OBS, wont change the quality - Only problem - You CAN NOT use the bluetooth microphone as your recording device.
Hope it helped :)
Much Love JP
It's not advice to use a BT mic or headset. It's a workaround for those who MUST use a BT headset. It's bluetooth itself that is the problem, not OBS. If you can use anything other than bluetooth, DO!!How the F*** did this garbage advice help anyone!? Are you all insane!?
You have a BT mic configured *somewhere* in your OBS configuration. Look around and dig for it; there are several places it could be hiding, all of which are useful for somebody to have it there. Once you no longer have it, and OBS is no longer asking for it - restart OBS to be sure, and maybe the entire computer to be extra sure - and no other program is asking for it either - restart after fixing them too - then the headset can stay in the higher-quality speaker-only mode.What I want to know is why the hell every time I open the OBS software the audio turns to s***. As far as I can tell, some a******** programmer at OBS created a few hidden obstacles to make the software inconvenient that you have to hunt down and find...
This is the true answer. I created an account to thank you!I found a workaround. Change the Mic/Aux to something else. Then I can still use my mic in Zoom, Teams, etc...just not for recording in OBS. Which I don't do anyway.
So if you use OBS to send video to a conferencing service using Virtual Camera, and you have this issue, make sure the conferencing system is using the proper mic and change OBS so it isn't trying to use a Bluetooth microphone. Best of both worlds, and you don't have to change any global Windows settings.
created an account to say thanks keeping up with the trend thank you worked perfectlyHey, (in windows 11) you can fix this, by going to setting/system/sound/input/"BLUETOOTH_MICROPHONE" (Click The ">" in the right side) - Chose "Do NOT allow windows to use this microphone/input device" - After that OBS, wont change the quality - Only problem - You CAN NOT use the bluetooth microphone as your recording device.
Hope it helped :)
Much Love JP
Thank you for the suggestion. One potential solution could involve blocking a specific device (such as a BT headset) from OBS in particular. I attempted to implement this by modifying the registry, but as I'm not an expert in this area, I encountered challenges. Nonetheless, I wanted to share this idea in case someone with more expertise can develop a solution. Cheers for considering this approach.Hey, (in windows 11) you can fix this, by going to setting/system/sound/input/"BLUETOOTH_MICROPHONE" (Click The ">" in the right side) - Chose "Do NOT allow windows to use this microphone/input device" - After that OBS, wont change the quality - Only problem - You CAN NOT use the bluetooth microphone as your recording device.
Hope it helped :)
Much Love JP
Made an account to thank you MY guy! I stream with the same username im commenting with and you just fixed a huge problem I always had. Sucks I can't use my Bluetooth mic but I'll live . YOU THE MANHey, (in windows 11) you can fix this, by going to setting/system/sound/input/"BLUETOOTH_MICROPHONE" (Click The ">" in the right side) - Chose "Do NOT allow windows to use this microphone/input device" - After that OBS, wont change the quality - Only problem - You CAN NOT use the bluetooth microphone as your recording device.
Hope it helped :)
Much Love JP
Thanks for the solution! The noise bother me a lot :)Hey, (in windows 11) you can fix this, by going to setting/system/sound/input/"BLUETOOTH_MICROPHONE" (Click The ">" in the right side) - Chose "Do NOT allow windows to use this microphone/input device" - After that OBS, wont change the quality - Only problem - You CAN NOT use the bluetooth microphone as your recording device.
Hope it helped :)
Much Love JP
I discovered a solution if you're using Mac. It's pretty straight forward.Whenever I open OBS, it changes the audio quality of whatever I'm listening to--before I'm even streaming or recording. It never used to do this before updating to Windows 11. Is anyone else experiencing muffled audio quality as soon as OBS is open or know how to fix it?
That solved my issue and I wanted to join in so I created an account just to thank you.Hey, (in windows 11) you can fix this, by going to setting/system/sound/input/"BLUETOOTH_MICROPHONE" (Click The ">" in the right side) - Chose "Do NOT allow windows to use this microphone/input device" - After that OBS, wont change the quality - Only problem - You CAN NOT use the bluetooth microphone as your recording device.
Hope it helped :)
Much Love JP
created an account to say thank you so much! Love yaI found a workaround. Change the Mic/Aux to something else. Then I can still use my mic in Zoom, Teams, etc...just not for recording in OBS. Which I don't do anyway.
I was using a bluetooth headset with no intention of using the mic, your post helped a lot.Hey, (in windows 11) you can fix this, by going to setting/system/sound/input/"BLUETOOTH_MICROPHONE" (Click The ">" in the right side) - Chose "Do NOT allow windows to use this microphone/input device" - After that OBS, wont change the quality - Only problem - You CAN NOT use the bluetooth microphone as your recording device.
Hope it helped :)
Much Love JP
Just wanted to say a huge thank you! Disabling the Bluetooth microphone in Windows settings solved the issue for me. Simple and effective!Hey, (in windows 11) you can fix this, by going to setting/system/sound/input/"BLUETOOTH_MICROPHONE" (Click The ">" in the right side) - Chose "Do NOT allow windows to use this microphone/input device" - After that OBS, wont change the quality - Only problem - You CAN NOT use the bluetooth microphone as your recording device.
Hope it helped :)
Much Love JP
