L lusfilip New Member May 25, 2018 #1 My OBS crash on opening... I try reinstall 2 times (deleting user configs) and nothing happen This is Crash report and log report Help mee Attachments Crash 2018-05-24 20-56-14.txt Crash 2018-05-24 20-56-14.txt 42.6 KB · Views: 67 2018-05-24 20-56-04.txt 2018-05-24 20-56-04.txt 2.8 KB · Views: 72
Suslik V Active Member May 25, 2018 #3 This is crash in the AMD Advanced Media Framework Encoder Plugin for OBS Studio that is part of the OBS Studio. Your video driver is too old for this plugin to work. You may try to update it manually: https://support.amd.com/en-us/download/mobile?os=Windows 10 - 64
L lusfilip New Member May 26, 2018 #4 Suslik V said: This is crash in the AMD Advanced Media Framework Encoder Plugin for OBS Studio that is part of the OBS Studio. Your video driver is too old for this plugin to work. You may try to update it manually: https://support.amd.com/en-us/download/mobile?os=Windows 10 - 64 Click to expand... is strange because i have left this pluggin and nothing happening
Suslik V Active Member May 26, 2018 #5 What does it mean? You have updated your video driver? Please, post new log-file then.
