OBS is stuck at 15-19 FPS
LordAdrøx
OBS is stuck at 15-19 FPS even when I have nothing but OBS running it still shows my FPS at 17 and no settings I change seem to do anything. I even set all OBS settings to the lowest the could possibly go and I still had about 15 FPS and it changed nothing. I have been able to use OBS in the past without problems I could stream at a nice 60 FPS without problems until just recently when OBS refuses to go over 15 FPS and it's frustrating because even when I touch no settings OBS seems to break itself ever couple of months.
That's just black. Please test it with an image / video / game in ti.
Also, do a test stream/recording of more than 30 seconds and post the URL or attach the log file of it.
I mainly just added that image to show you the frame rate in the bottom right. I have no game running or anything and it's like that and if I were to have a video captured you'd see a low frame rate
Please review and follow directions and recommendations on the analyzer:
You have some major issues in there.
Also, remove this:
21:10:46.709: Avira Antivirus: enabled (AV)
21:10:46.709: Norton Security Ultra: disabled (AV)
As far as you understand this is your production computer and you work with it you'll need no other antivirus more than win defender.
