Question / Help OBS only picks up Desktop Audio
ljbty
I am having an issue with all audio inputs. I use a Roland Duo-Capture EX with a Behringer B2 Pro, this setup is known good as I can record perfectly fine in Cubase.
I have been through the Windows troubleshooter to no prevail, I have even plugged a microphone into the 3.5mm jack and that still does not work.
On the screenshot I have attached you can clearly see that it is forcing the mic into a mono mix-down which is what I would want however I can not change this back.
Steps I have already done to try to fix this:
Re-installed OBS Studio (Several times, including older versions)
Re-installed Windows
Re-installed Roland Drivers
Tried 2 other audio inputs
+Others over the past 12 hours...
