OBS Stream Crashing |60-100% of GPU (prevails after stream)| High CPU usage -> freezes/crashes stream
niknes
Hello,
I’ve been experiencing issues while streaming with OBS where my stream freezes or crashes when CPU usage spikes high. Despite extensive troubleshooting, I haven’t been able to resolve the problem and need help identifying the root cause.
I've noticed some time ago, that the GPU usage spikes after some time hits around 65-100% and stays on about 65% even after stream. (Idle after opening about 8% cpu, 17% gpu)
I know with the "source record", and with that recording multiple sources, I am using more resources than normal, but until about 2 weeks ago it has never been a big issue. No spikes, no crashes.
I thought it might be the new game I started, but I reduced the quality without much change and it started happening to other less intense games too.
I checked the OBS analyzer, I hit a Max Audio Buffer with my "Razer Kiyo Pro" (https://obsproject.com/logs/ypqcOu3y7TQEXQt5), but I've seem to have fixed that, without changing the result of this problem...
I changed the multiple game captures (https://obsproject.com/logs/jmjObivE4IuzNCKh), I made my scenes as easy as possible, I removed the "face tracker" plugin (one of the only things I can think of that I changed), made nested scenes easier, put all of my alerts and chats in as little of browser sources as possible.
There are no red nor orange reports through the OBS analyzer now (https://obsproject.com/logs/usO3jU7uBqJc0fFv), but I'm still hitting the highs of CPU (about 40%, bringing my cpu to 100% for some reason) and GPU (as I said 60-100%).
What seems to have been always weirdly high is my average time to render frame about 16.3 ms even if I have OBS open without streaming. (attached)
I left it open while I was gone, maybe this crash report can help too: https://obsproject.com/logs/3RXgrY5RylTRN5Lk
I'm at a loss here and I just want to enjoy streaming T-T
PC Specs:
CPU: Intel Core i9-10900K
GPU: NVIDIA RTX 3080
RAM: 64GB DDR4
I also use Audio Monitor and Move source
I really hope you can help me and I appreciate every idea or help I can get.
Thank you in advance,
NikNes
  • Crash 2024-12-19 00-07-13.txt
  • Crash 2024-12-18 19-16-03.txt
There's lots o slop in those logs.
Move & Source Record plugins are stale, update them & see if things improve.
16:44:38.196: [Move Transition] loaded version 2.8.0
16:44:40.371: Failed to load 'en-GB' text for module: 'source-record.dll'
16:44:40.371: [Source Record] loaded version 0.3.1
I updated the plugins, the average render time seems to have gotten down a bit, but there was still a ~99% gpu spike of obs (Up to 70% gpu usage is somewhat fine, after that the frames are dropping fast xp)
Here's the log file https://obsproject.com/logs/23zw92wdOBt7V4rs
I hope there's less slop now tho haha
And thanks for the help ^^
Sounds like there was some improvement but the log ends before you stopped encoding. The tiny tubular task thread crashing is caused by a plugin. Fix the resolution on this encode, maybe it's causing issues with Source Record or the encoder itself.
20:57:26.302: [ffmpeg muxer: 'Source Record'] Writing file 'D:/Videos/Raw/Streams/Games/Monitor-2024-12-20 20-57-25.mkv'...
20:57:26.461: [obs-nvenc: 'Source Record'] settings:
20:57:26.461: codec: H264
20:57:26.461: rate_control: CQP
20:57:26.461: bitrate: 0
20:57:26.461: cqp: 15
20:57:26.461: keyint: 60
20:57:26.461: preset: p6
20:57:26.461: tuning: hq
20:57:26.461: multipass: qres
20:57:26.461: profile: high
20:57:26.461: width: 1924
20:57:26.461: height: 1082
20:57:26.461: b-frames: 2
20:57:26.461: lookahead: true
20:57:26.461: psycho_aq: true
20:57:26.461:
20:57:27.333: ---------------------------------
20:57:27.334: [FFmpeg aac encoder: 'Source Record'] bitrate: 128, channels: 2, channel_layout: stereo
20:43:13.066: Game Bar: On > Off
20:43:13.066: Game DVR: On > Off
This plugin is not installed
0:43:19.106: - source: 'Sebi' (image_source)
20:43:19.106: - filter: 'Scale To Sound' (scale_to_sound)
20:43:19.106: - filter: 'Scale To Sound 2' (scale_to_sound)
Bad Scene, there may be more....
20:43:19.106: - scene 'Games':
20:43:19.106: - source: 'Game monitor' (group)
20:43:19.106: - filter: 'Source Record' (source_record_filter)
20:43:19.106: - source: 'League2' (window_capture)
20:43:19.106: - source: 'any foreground' (game_capture)
20:43:19.106: - source: 'clip studio' (window_capture)
20:43:19.106: - source: 'Opera' (window_capture)
20:43:19.883: Failed to open file 'D:/# Storage/Preparation/Camera/cam3.png': No such file or directory
20:43:19.884: WIC: Failed to create IWICBitmapDecoder from file: D:/# Storage/Preparation/Camera/cam3.png
20:43:19.884: gs_image_file_init_internal: Failed to load file 'D:/# Storage/Preparation/Camera/cam3.png'
20:43:19.886: NV12 texture support enabled
20:43:19.886: P010 texture support not available
20:43:20.005: NV12 texture support enabled
20:43:20.005: P010 texture support not available
20:43:20.008: NV12 texture support enabled
20:43:20.008: P010 texture support not available
20:43:20.011: NV12 texture support enabled
20:43:20.011: P010 texture support not available
20:43:20.016: Failed to open file 'C:/Users/User/Downloads/black-rectangle.png': No such file or directory
20:43:20.016: WIC: Failed to create IWICBitmapDecoder from file: C:/Users/User/Downloads/black-rectangle.png
20:43:20.016: gs_image_file_init_internal: Failed to load file 'C:/Users/User/Downloads/black-rectangle.png'
20:43:20.017: Failed to open file 'C:/Users/User/Downloads/black-rectangle2.png': No such file or directory
20:43:20.017: WIC: Failed to create IWICBitmapDecoder from file: C:/Users/User/Downloads/black-rectangle2.png
20:43:20.017: gs_image_file_init_internal: Failed to load file 'C:/Users/User/Downloads/black-rectangle2.png'
20:43:20.017: Failed to open file 'C:/Users/User/Downloads/rounded-rectangle.png': No such file or directory
20:43:20.017: WIC: Failed to create IWICBitmapDecoder from file: C:/Users/User/Downloads/rounded-rectangle.png
20:43:20.017: gs_image_file_init_internal: Failed to load file 'C:/Users/User/Downloads/rounded-rectangle.png'
20:43:20.017: Failed to open file 'D:/# Storage/Preparation/Camera/cam3.png': No such file or directory
20:43:20.017: WIC: Failed to create IWICBitmapDecoder from file: D:/# Storage/Preparation/Camera/cam3.png
20:43:20.017: gs_image_file_init_internal: Failed to load file 'D:/# Storage/Preparation/Camera/cam3.png'
20:43:20.017: Failed to open file 'C:/Users/User/Downloads/fague-smoother-rounded-rectangle.png': No such file or directory
20:43:20.017: WIC: Failed to create IWICBitmapDecoder from file: C:/Users/User/Downloads/fague-smoother-rounded-rectangle.png
20:43:20.017: gs_image_file_init_internal: Failed to load file 'C:/Users/User/Downloads/fague-smoother-rounded-rectangle.png'
20:43:20.017: Failed to open file 'C:/Users/User/Downloads/black-rectangle.png': No such file or directory
20:43:20.018: WIC: Failed to create IWICBitmapDecoder from file: C:/Users/User/Downloads/black-rectangle.png
20:43:20.018: gs_image_file_init_internal: Failed to load file 'C:/Users/User/Downloads/black-rectangle.png'
20:43:20.018: Failed to open file 'C:/Users/User/Downloads/black-rectangle2.png': No such file or directory
20:43:20.018: WIC: Failed to create IWICBitmapDecoder from file: C:/Users/User/Downloads/black-rectangle2.png
20:43:20.018: gs_image_file_init_internal: Failed to load file 'C:/Users/User/Downloads/black-rectangle2.png'
20:43:20.018: Failed to open file 'C:/Users/User/Downloads/smoother-rounded-rectangle2.png': No such file or directory
20:43:20.018: WIC: Failed to create IWICBitmapDecoder from file: C:/Users/User/Downloads/smoother-rounded-rectangle2.png
20:43:20.018: gs_image_file_init_internal: Failed to load file 'C:/Users/User/Downloads/smoother-rounded-rectangle2.png'
20:43:20.018: Failed to open file 'C:/Users/User/Downloads/fague-smoother-rounded-rectangle.png': No such file or directory
20:43:20.018: WIC: Failed to create IWICBitmapDecoder from file: C:/Users/User/Downloads/fague-smoother-rounded-rectangle.png
20:43:20.018: gs_image_file_init_internal: Failed to load file 'C:/Users/User/Downloads/fague-smoother-rounded-rectangle.png'
20:43:20.035: NV12 texture support enabled
20:43:20.035: P010 texture support not available
20:43:20.100: Failed to open file 'C:/Users/User/Downloads/black-rectangle.png': No such file or directory
20:43:20.100: WIC: Failed to create IWICBitmapDecoder from file: C:/Users/User/Downloads/black-rectangle.png
20:43:20.100: gs_image_file_init_internal: Failed to load file 'C:/Users/User/Downloads/black-rectangle.png'
20:43:20.100: Failed to open file 'C:/Users/User/Downloads/black-rectangle2.png': No such file or directory
20:43:20.100: WIC: Failed to create IWICBitmapDecoder from file: C:/Users/User/Downloads/black-rectangle2.png
20:43:20.100: gs_image_file_init_internal: Failed to load file 'C:/Users/User/Downloads/black-rectangle2.png'
20:43:20.100: Failed to open file 'C:/Users/User/Downloads/rounded-rectangle.png': No such file or directory
20:43:20.100: WIC: Failed to create IWICBitmapDecoder from file: C:/Users/User/Downloads/rounded-rectangle.png
20:43:20.100: gs_image_file_init_internal: Failed to load file 'C:/Users/User/Downloads/rounded-rectangle.png'
20:43:20.123: Failed to open file 'C:/Users/User/Downloads/fague-smoother-rounded-rectangle.png': No such file or directory
20:43:20.123: WIC: Failed to create IWICBitmapDecoder from file: C:/Users/User/Downloads/fague-smoother-rounded-rectangle.png
20:43:20.123: gs_image_file_init_internal: Failed to load file 'C:/Users/User/Downloads/fague-smoother-rounded-rectangle.png'
20:43:20.123: NV12 texture support enabled
20:43:20.123: P010 texture support not available
20:43:20.270: NV12 texture support enabled
20:43:20.270: P010 texture support not available
20:43:20.370: NV12 texture support enabled
20:43:20.370: P010 texture support not available
20:43:20.508: NV12 texture support enabled
20:43:20.508: P010 texture support not available
I would disable Hardware accelerated decoding for these (2) Media Sources.
20:43:20.569: input: D:/Preparation/profounder/profounder_stinger_new/Footage/WEBM with transparent background/template.webm
20:43:20.569: input_format: (null)
20:43:20.569: speed: 100
20:43:20.569: is_looping: no
20:43:20.569: is_linear_alpha: no
20:43:20.569: is_hw_decoding: yes
20:43:20.569: is_clear_on_media_end: yes
20:43:20.569: restart_on_activate: yes
20:43:20.569: close_when_inactive: no
20:43:20.569: full_decode: no
20:43:20.569: ffmpeg_options:
20:43:20.569: [Media Source 'Profile Stinger (Stinger)']: settings:
Tons of SE, java script errors that could be wasting resources. Most appear to be browser sources, cleaning them up would be a good thing to do.
For the encoding, all (8) encodes can be completed with the 3080. Just need to use lower presets. Or you can do some of the encodes with the iGPU to free up some headroom on your CPU.
This is a great reference, check out Table 2.
I removed some stuff, but I'll just be able to test it in some days xp
I really appreciate your help ^^
So going through your messages:
I have no idea why it was not 1920x1080, nor how to really change it ^^' - But there is a "scale" unchecked with a greyed out 0x0, so either I clicked something and fixed it or I might to manually need to put it to 1920x1080, but I'll find that out after the next test/analyze file.
What do you want to tell me through:
20:43:13.066: Game DVR: On > Off "? ^^'
I didn't know turned of filters would be so demanding still, but I think I removed everything unnecessary of what you sent me (scale to sound and old directories).
I put of both of the accelerations.
Which of the 13 browser sources might be a problem? Multiple are chat add-ons which I use frequently, alerts, ads... -> Not much I can change or easily funnel into another :/
Do you have an idea?
I thought with Overlays, Alerts and Chat being source recorded on Software x264 CBR, 500Kbps and ultrafast I might use very little CPU
The Cam and the Game might use more GPU with Hardware (NVENC, H.264) CQP ~15/16, with the stream those are 6 Encodes?
Even more, I haven't changed those in months, why would it be a problem now? :/
Anyway, thank you for the help, I'll keep you updated soon and for now Merry Christmas ^^
Really need a new/complete log now that there have been plugins updated & other changes made. The screen shots you posted above in your first post show that you have/had rendering lag (GPU overload) & I'm not sure if it's still overloaded since the log provided after the updates were made was incomplete.
I don't use Source Record so I'm not going to be able to help much with the settings. I do use the Multi-RTMP Output plugin & that does have a field for setting the output resolution.
You can disable Game Bar & Game DVR (Captures) in Windows Gaming as they're not needed & can waste resources.
It looks like most if not all 13 of them are throwing errors. Check the log(s) & look for this stuff.
20:43:20.620: [obs-browser: 'End_of_stream'] Error: [Report Only] Refused to load the script 'https://streamelements.com/z/i.js' because it violates the following Content Security Policy directive: "script-src 'none'". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
20:43:20.620: (https://streamelements.com/overlay/...PI11ig93U6Xrqphfk9MPP7Lphbkb4cUNEUH2vZKyTiA:0)
20:43:20.634: [obs-browser: 'social stream chat - opera'] Error: Uncaught (in promise) NotAllowedError: Failed to execute 'request' on 'WakeLock': The requesting page is not visible (https://socialstream.ninja/dock.htm...alignbottom&openchat&firstnames&hidebots:8992)
20:43:20.794: [obs-browser: 'End_of_stream'] Error: [Report Only] Refused to execute inline script because it violates the following Content Security Policy directive: "script-src 'none'". Either the 'unsafe-inline' keyword, a hash ('sha256-fO0h6nSVSg6QGOtEkqzxNcpe9iJLgXxfCBJTJ4butWU='), or a nonce ('nonce-...') is required to enable inline execution.
20:43:20.794: (https://streamelements.com/z/i.js:1)
20:43:20.799: [obs-browser: 'End_of_stream'] Error: [Report Only] Refused to execute inline script because it violates the following Content Security Policy directive: "script-src 'none'". Either the 'unsafe-inline' keyword, a hash ('sha256-KCmvfYOVwxKHM2ghwyNvM4i/jF1XG634uBPsLdo0rHs='), or a nonce ('nonce-...') is required to enable inline execution.
20:43:20.799: (https://streamelements.com/overlay/...PI11ig93U6Xrqphfk9MPP7Lphbkb4cUNEUH2vZKyTiA:4)
20:43:21.121: [obs-browser: 'Mega-Chat'] Error: [Report Only] Refused to load the script 'https://streamelements.com/z/i.js' because it violates the following Content Security Policy directive: "script-src 'none'". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
20:43:21.121: (https://streamelements.com/overlay/...PI11ig93U6Xrqphfk9MPP7Lphbkb4cUNEUH2vZKyTiA:0)
20:43:21.122: [obs-browser: 'End_of_stream'] Error: zaraz is loaded twice (https://streamelements.com/overlay/...PI11ig93U6Xrqphfk9MPP7Lphbkb4cUNEUH2vZKyTiA:4)
20:43:21.122: [obs-browser: 'End_of_stream'] Error: [Report Only] Refused to execute inline script because it violates the following Content Security Policy directive: "script-src 'none'". Either the 'unsafe-inline' keyword, a hash ('sha256-fO0h6nSVSg6QGOtEkqzxNcpe9iJLgXxfCBJTJ4butWU='), or a nonce ('nonce-...') is required to enable inline execution.
20:43:21.122: (https://streamelements.com/overlay/...PI11ig93U6Xrqphfk9MPP7Lphbkb4cUNEUH2vZKyTiA:4)
Still got about the same amount of rendering lag (overload) going on, get rid of that rendering lag & things will look even better. You cleaned up most of those SE errors but a few of them still remain.
Is OBS still crashing on exit?
19:02:34.344: [ffmpeg muxer: 'Source Record'] Output of file 'D:/Videos/Raw/Streams/Overlays/alerts/Alerts-2024-12-25 17-00-10.mkv' stopped
19:02:34.344: Output 'Source Record': stopping
19:02:34.344: Output 'Source Record': Total frames output: 220269
19:02:34.344: Output 'Source Record': Total drawn frames: 219888 (220313 attempted)
19:02:34.344: Output 'Source Record': Number of lagged frames due to rendering lag/stalls: 425 (0.2%)
19:02:34.344: [ffmpeg muxer: 'Source Record'] Output of file 'D:/Videos/Raw/Cam/Cam-2024-12-25 17-00-10.mkv' stopped
19:02:34.345: Output 'Source Record': Total frames output: 220265
19:02:34.345: Output 'Source Record': Total drawn frames: 219883 (220308 attempted)
19:02:34.345: Output 'Source Record': Number of lagged frames due to rendering lag/stalls: 425 (0.2%)
19:02:34.354: Video stopped, number of skipped frames due to encoding lag: 427/220306 (0.2%)
19:02:34.362: [ffmpeg muxer: 'Source Record'] Output of file 'D:/Videos/Raw/Streams/Games/Monitor-2024-12-25 17-00-10.mkv' stopped
19:02:34.362: Output 'Source Record': stopping
19:02:34.362: Output 'Source Record': Total frames output: 220269
19:02:34.362: Output 'Source Record': Total drawn frames: 219881 (220306 attempted)
19:02:34.362: Output 'Source Record': Number of lagged frames due to rendering lag/stalls: 425 (0.2%)
19:02:34.383: [ffmpeg muxer: 'Source Record'] Output of file 'D:/Videos/Raw/Streams/Overlays/overlay/Overlays-2024-12-25 17-00-10.mkv' stopped
19:02:34.383: Output 'Source Record': stopping
19:02:34.383: Output 'Source Record': Total frames output: 110107
19:02:34.383: Output 'Source Record': Total drawn frames: 219889 (220314 attempted)
19:02:34.383: Output 'Source Record': Number of lagged frames due to rendering lag/stalls: 425 (0.2%)
19:02:34.391: [ffmpeg muxer: 'Source Record'] Output of file 'D:/Videos/Raw/Streams/Overlays/chat/Chat-2024-12-25 17-00-10.mkv' stopped
19:02:34.391: Output 'Source Record': stopping
19:02:34.391: Output 'Source Record': Total frames output: 36690
19:02:34.391: Output 'Source Record': Total drawn frames: 219888 (220313 attempted)
19:02:34.391: Output 'Source Record': Number of lagged frames due to rendering lag/stalls: 425 (0.2%)
19:02:34.424: Video stopped, number of skipped frames due to encoding lag: 425/220305 (0.2%)
19:02:34.483: warning: 2 frames left in the queue on closing
19:02:34.594: warning: 2 frames left in the queue on closing
19:02:34.643: warning: 2 frames left in the queue on closing
19:02:34.693: warning: 2 frames left in the queue on closing
19:02:34.766: warning: 2 frames left in the queue on closing
19:02:35.953: Output 'Replay Buffer': stopping
19:02:35.953: Output 'Replay Buffer': Total frames output: 220393
19:02:35.953: Output 'Replay Buffer': Total drawn frames: 220018 (220443 attempted)
19:02:35.953: Output 'Replay Buffer': Number of lagged frames due to rendering lag/stalls: 425 (0.2%)
19:02:35.958: ==== Replay Buffer Stop ============================================
19:02:36.033: [rtmp stream: 'adv_stream'] User stopped the stream
19:02:36.033: [rtmp stream: 'adv_stream'] Socket send buffer is 1048576 bytes
19:02:36.034: Output 'adv_stream': stopping
19:02:36.034: Output 'adv_stream': Total frames output: 220293 (220314 attempted)
19:02:36.034: Output 'adv_stream': Total drawn frames: 220025 (220450 attempted)
19:02:36.034: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 425 (0.2%)
19:02:36.034: Output 'adv_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 21 (0.0%)
19:02:36.037: Video stopped, number of skipped frames due to encoding lag: 434/220445 (0.2%)
19:02:36.043: ==== Streaming Stop ================================================
19:02:36.253: warning: 2 frames left in the queue on closing
The audio lag may be due to system overload or something else. Currently almost all audio inputs are set to Use Device Timing. I would change this up & only use device timing for (1) audio input, for the rest of them disable it as there's no way all of those sources are arriving to OBS at the same exact time.
16:10:19.738: [win-wasapi: 'Music'] update settings:
16:10:19.738: device id: {0.0.0.00000000}.{6fea4c66-7a41-436f-a5ad-12e7e91b3c9c}
16:10:19.738: use device timing: 1
16:10:19.739: [WASAPISource::TryInitialize]:[{0.0.0.00000000}.{6fea4c66-7a41-436f-a5ad-12e7e91b3c9c}] Failed to enumerate device: 80070490
16:10:19.739: WASAPI: Device '{0.0.0.00000000}.{6fea4c66-7a41-436f-a5ad-12e7e91b3c9c}' failed to start (source: Music)
16:10:19.739: [win-wasapi: 'In-S-Music'] update settings:
16:10:19.739: device id: {0.0.0.00000000}.{b83e6583-8860-439b-83ed-ee7912854870}
16:10:19.739: use device timing: 1
16:10:19.740: [win-wasapi: 'Discord'] update settings:
16:10:19.740: device id: {0.0.0.00000000}.{2d9a9036-aa28-496a-aad8-2f8b7f9a2af4}
16:10:19.740: use device timing: 1
16:10:19.741: [win-wasapi: 'Desktop'] update settings:
16:10:19.741: device id: {0.0.0.00000000}.{d75bf394-ebff-406f-a3e2-3db20a213a11}
16:10:19.741: use device timing: 1
6:10:21.550: [win-wasapi: 'Ambience'] update settings:
16:10:21.550: device id: {0.0.0.00000000}.{cb0b05e8-e91b-458e-a47c-26e3931c09c3}
16:10:21.550: use device timing: 1
16:10:21.556: [win-wasapi: 'Browser'] update settings:
16:10:21.556: device id: {0.0.0.00000000}.{0faa6246-36aa-4571-861d-7a92386b0cf6}
16:10:21.556: use device timing: 1
16:56:48.213: Max audio buffering reached!
16:56:48.213: adding 917 milliseconds of audio buffering, total audio buffering is now 960 milliseconds (source: Ambience)
16:56:48.213:
16:56:48.234: Source Ambience audio is lagging (over by 1936107.74 ms) at max audio buffering. Restarting source audio.
For the next test, try creating a new Scene Collection with just (1) Scene/Source. This will eliminate all the filters/errors in the current Profile. If things look good on the new collection, then we can be fairly certain that there's something in the current Profile slowing things down.
Sorry for the late reply, I've been sick...
Yeah, I tried putting all the settings down a small amount.
The crash on exit has not happened so far.
I changed all of the monitors to 60 Hz and put the game on 60/30 Fps.
I changed all the device stamps to 0, except for my mic I think.
Here's another stream with the normal settings. I don't know why the audio sample rate is different with one audio source, because I didn't change anything, but I changed it back already:
Here's a stream with just one scene. What is weird is that it is telling me it had multiple captures (I deleted a _window_ capture right before the stream, otherwise this (screenshot) is all the sources I have, no filters, nothing):
Some improvement but your GPU is still slightly overloaded
15:45:16.626: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 154 (0.1%)
15:45:16.626: Output 'adv_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 23 (0.0%)
15:45:16.628: Video stopped, number of skipped frames due to encoding lag: 154/118785 (0.1%)
Second log, cleaning up Scenes getting better.....
12:07:53.761: Loaded scenes:
12:07:53.761: - scene 'Scene':
12:07:53.761: - source: 'Window Capture' (window_capture)
12:07:53.761: - source: 'Game Capture' (game_capture)
12:07:53.761: - source: 'Audio Input Capture' (wasapi_input_capture)
12:07:53.761: - source: 'Audio Output Capture' (wasapi_output_capture)
12:07:53.761: - source: 'Text (GDI+)' (text_gdiplus_v3)
14:54:46.482: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 49 (0.0%)
14:54:46.482: Output 'adv_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 48 (0.0%)
14:54:46.486: ==== Streaming Stop ================================================
14:54:46.611: Output 'Replay Buffer': stopping
14:54:46.611: Output 'Replay Buffer': Total frames output: 157321
14:54:46.611: Output 'Replay Buffer': Total drawn frames: 157304 (157353 attempted)
14:54:46.611: Output 'Replay Buffer': Number of lagged frames due to rendering lag/stalls: 49 (0.0%)
14:54:46.611: ==== Replay Buffer Stop ============================================
14:54:46.614: Video stopped, number of skipped frames due to encoding lag: 49/157351 (0.0%)
Big improvement here, one or more of the plugins more than likely to blame.
1st log posted
23:01:49.623: Number of memory leaks: 3963
1st of today's logs
15:50:36.082: Number of memory leaks: 2
More proof of improvement but still on the slow side....
12/17/24
23:01:48.983: audio_thread(Audio): min=0.014 ms, median=4.594 ms, max=782.465 ms, 99th percentile=30.285 ms
23:01:48.983: obs_graphics_thread(33.3333 ms): min=0.086 ms, median=18.781 ms, max=3597.28 ms, 99th percentile=30.66 ms, 99.476% below 33.333 ms
Today
15:50:35.501: audio_thread(Audio): min=0.014 ms, median=0.262 ms, max=380.353 ms, 99th percentile=25.099 ms
15:50:35.501: obs_graphics_thread(33.3333 ms): min=0.071 ms, median=2.732 ms, max=3140.01 ms, 99th percentile=20.401 ms, 99.5589% below 33.333 ms
I don't think there is much I can change as of now and I've been streaming some days now and it has been great so far, regarding the lag/crashes.
I'll be sure to write again if there are more problems occurring.
Thank you for so much for your help and time.
