Production Pro Theme
Production Pro Theme 2.0.1
Monsteer
Monsteer submitted a new resource:
Production Pro Theme - Theme for live stream events
Production Pro Theme for OBS Studio
This theme is designed for people who need to broadcast live events with a simple compact design and adapted to the most essential plugins.
It is still a work in progress, it needs to be more polished but it is fully functional.
Example of a plugin adaptation:
Conventional t-bar and sliders (WIP):
View attachment 103599...
Nice theme! Been looking for something like this. If I could come with a feedback it would be to make the buttons more fresh looking. The gradient reminds me of the websites from the 2000s :P
I really appreciate all the feedback you are providing ❤
I take into account all ideas and suggestions.
The new theme system in version 30.2 makes it easier to have multiple versions of the same theme, i will try to create different ones with your ideas.
This theme is impressive, I can't wait for a new update, if it's not too much to ask, could you reduce what I show in the image marked in red? That preview and program are glued together, and that those controls are along below or above is also an important possibility. thanks for sharing. thanks thanks
Hello developers,
I have a suggestion for improvement;
- Add the color identification Green (Preview) and Red (Program) to the scene grid for better visualization.
Here is an example image:
The theme is very good. Congratulations and thank you.
I managed to change the colors of all the buttons:
- Selected to Green
- Hover to Yellow
...but I couldn't find any code that enabled a color for Scene Program
This option of leaving the Scene in red when it is in Program, would help me a lot in viewing the scene that is in live.
After update 31.1.2 the theme fails, the control colors no longer appear. When I click start broadcast, or start virtual camera, the theme colors no longer appear.
Monsteer updated Production Pro Theme with a new update entry:
Update for OBS Studio v31.1
  • Updated to the v31.1 changes
  • Added font size option in the new appearance options, density still not working (wip)
  • Fix for Aitum Multistream plugin color buttons
  • Small fixes
**IMPORTANT**
The Streamlabs plugin for OBS does not allow the stream button color to be changed when it is active.
Thanks to EmilioDelMuseo and bambampl for their comments/suggestions.
