probbed_seq'
At First, my Problem;_
Guessed from Title, i can't figure out how to setup
OBS correctly.
I want to capture Gameplay with my Razer Ripsaw (NOT HD !!) and can't
hear Audio from the Gameplay "in Preview"/ in the Interface of OBS.
As I tried yesterday, Gameplay-Audio was hearable, but it sounded
- crackling
- like twice the Audio above each other, kinda "overcharged"
My OBS-Setup, replicated from Tutorial;
I have setup 1 Scene.
I have setup 1 Source.
My Source i have setup as follows;
- adding Video Capture-Device (+)
- Device: "Razer Ripsaw Game Capture Card Video"
- Resolution/ FPS-Type: Custom
- Resolution: 1920 x 1080
- FPS: 60
- Video Format: YUY 2
- Color Space: Rec. 709
- Color Range: Default
- all the other Stuff i have left unchanged.
To my PC-Setup:
- Graphics Card: NVIDIA GeForce GTX 960
- CPU: Intel i7 6700K
- 2 HDDs and 1 SSD (can't give you the Names, sorry)
Info to my Screen:;
- hp 27es, here a Link, if it's relevant;
https://support.hp.com/sg-en/document/c05078320
The Type of Capture-Card in use;
- Razer Ripsaw RZ20-01780
Link 4 check;
- the Screen has no integrated Speaker System, so I have to hear Gameplay throught
connecting my Headset to my Xbox One-Controller.
Note:
When I want to hear Audio from my PC, i usually plug this portable Speaker into it;
- Blaupunkt BTR 60 BK
here a Link, if needed;
https://www.idealo.de/preisvergleich/OffersOfProduct/6183668_-btr-60-blaupunkt.html#datasheet
I'm sure you need more Information, so just ask, if anything's missing.
Thanx upfront, if you decide to spend time on this probably easy request.
Extra Note [!!!]:
I reset my Sources, reconfigured the Ripsaw as Source, set everything as before
and it sorta "FIXED" the Issue of not hearing anything.
Tho the captured Sound from my Xbox was now hearable again, so was the "Crackle"
I read in a different Thread, that the Audio-Sample-Rate could be the Issue.
I don't think it is.
Set both, OBS and the Speaker-Settings to 44,1 kHz Sample-rate and it's still unchanged.
OBS correctly.
- crackling
- FPS: 60
To my PC-Setup:
Info to my Screen:;
Link 4 check;
Note:
Extra Note [!!!]:
