Resource icon
OBS Lua Source toggler 0.0.4
Another small issue, maybe easy to solve: I use Sammi/Deck Hopper to toggle select and start these media sources in OBS, but the progress bar (in OBS source toolbar) will not link to the media source that is playing. That is, I have to click on it to activate the toolbar. Is there a way to automate this?
Never mind, just installed the media-controls plugin and the problem is solved...
This plugin has always been one of my go tos for stream. Combined with Source Dock, it's pretty A++ on usefulness. I basically dock the scene holding all my cams, game sources, audio, etc . . . and it makes it super easy to switch between them without having to go to the specific scene and so on. Press an eye all the rest deactivate and i only ever have one active item in the scene which is what I need.
I have encounted an issue recently though. . . I want to use Dual Output for future streams so I can output a vertical format vid along with my regular one. However, the toggle only works with the main horizontal output and does nothing for the vertical output. Is there anyway to have the toggle work with both outputs at the same time. Maybe some additional code to add in to make it work? Thanks!
When renaming scenes/groups you have to change them in the script as well. Would it be possible to auto-update them?
@nekobaby what are you using for dual output? With Aitum Vertical using the nested scenes it works as expected for me.
I suppose I could try it. I've been using the built-in dual output in Prism Launcher, since I like its features and I'm not a fan of Streamlabs. Pretty much all the OBS plugins work fine in Prism. I heard that Aitum can cause lag when streaming, if you think it's not an issue. . . then I'll switch from the dual and use Aitum instead. I'm serious that your source toggler is a go-to for me. I literally can't live without it. =P
Can you show an example of how you are using Vertical Aitum with the Source Toggler and Nested scenes? The way I'm doing it now is making me have a separate camera scene for horizontal and vertical . . . and I would need to have 2 separate source docks. I might be thinking about this wrong.
Hello.
I am trying to do something similar, with the goal of having an Aitum Vertical canvas closely mimic my main canvas. My issue stems from my desire to have the elements crop differently between the canvases, in order to accommodate the variation of their dimensions. My workaround has been to make each of my Vertical Sources in the desired vertical scene be a Group taken from a separate main scene – which allows for nothing to be cropped before reaching the vertical canvas. Then I can assign the same hotkeys to show each Group in the vertical scene as I have to show each corresponding parent scene on the main canvas. This is all good, until Source Toggler has no effect on the vertical scene's Groups. At present I am assigning multiple hotkeys to hide each other Group as one gets revealed, which I believe was itself the problem which Source Toggler had set out to address.
I don't know whether this suggestion is possible, but an update to Source Toggler to act upon Vertical Scenes would solve every issue I have. Absent of that, I think I would have to abandon one of my goals: either the different crops, or the tidy management of hotkeys.
