Question / Help Strange recording effects
wscieklakoala
Hi
I've got a problem with recordings. There is a strange visual effect on my recordings, it also changes the brightness when light elements shows up. Different settings and disc formatting doesn't work. What should I do to get rid of that problem?
Sorry about my english, I've tried to describe my problem as clear as possible.
My logs: https://obsproject.com/logs/2sOaeOJSFtkWagsx
OBS is loading the onboard Intel graphics device rather than the Nvidia GTX 1050Ti. The HD 630 doesn' t have x264 NVENC encoding.
Make sure you are choosing the right GPU number in the output settings for OBS.
09:26:44.491: [jim-nvenc: 'recording_h264'] init_session: nv.nvEncOpenEncodeSessionEx(&params, &enc->session) failed: 2 (NV_ENC_ERR_UNSUPPORTED_DEVICE)
09:05:06.174: Initializing D3D11...
09:05:06.174: Available Video Adapters:
09:05:06.179: Adapter 0: Intel(R) HD Graphics 630
09:05:06.179: Dedicated VRAM: 134217728
09:05:06.179: Shared VRAM: 4234582016
09:05:06.179: output 0: pos={0, 0}, size={1920, 1080}, attached=true
09:05:06.179: Adapter 1: NVIDIA GeForce GTX 1050 Ti
09:05:06.179: Dedicated VRAM: 4216324096
09:05:06.183: Loading up D3D11 on adapter Intel(R) HD Graphics 630 (0)
Change YUV mode from full back to partial. Full will create wrong brightness with some players and postprocessing software.
