Streamlabs Theme
Streamlabs Theme 1.1
Nicell
Nicell submitted a new resource:
StreamLabs Theme - A StreamLabs OBS Inspired Theme for OBS Studio
ABOUT
This theme is based on the StreamLabs OBS. It uses the Rachni theme included with OBS as a base. I definitely recommend installing Noto Sans if you do not already have it.
INSTALLATION
  1. Unzip the file
  2. Copy StreamLabs.qss to your OBS installation ...\obs-studio\data\obs-studio\themes (Default: C:\Program Files (x86)\obs-studio\data\obs-studio\themes)
  3. Launch OBS and select the StreamLabs theme...
Hey I love the theme but in studio mode, there is a white box. can you fix this area?
Hello! I've installed this theme and I've noticed that some buttons are missing compared to other themes.
There's a few different steps that go into the overlays. The general workflow involves designing graphics in Photoshop and importing them as image sources in Streamlabs OBS.
