Resource icon
StreamUP Chapter Marker XML converter for Premiere 1.0
shrugbuds
shrugbuds submitted a new resource:
StreamUP Chapter Marker XML converter for Premiere - Converts XML files so they can be used in Premiere Pro
This is a simple python script that converts the XML files created by StreamUP Chapter Marker Manager so that they can be read by Adobe Premiere Pro.
You must have python installed to run the script.
INSTRUCTIONS
1. Open your terminal/command window
2. Change directory to where you've saved convert_xml.py ( cd Directory/where/saved )
3. Enter: python convert_xml.py (note: in mac sometimes I have to use python3 as the command instead of python)
4. It will ask you for XML file path...
Hey I'm trying to get the StreamUp Chapter Marker XML Converter for Premiere working.
I open up the CMD and type:
( cd Directory/where/saved ) python convert_xml.py
After typing that I hit enter but I have an error message that always pops up.
"Python was unexpected at this time"
I am using python 3.12.8 with the latest version of OBS.
