Versus Ⓡevolution scoreboard
Free Versus Ⓡevolution scoreboard 2.4
Try this utility, it seems easier than emulating Windows. Tell us about the result :)
Hi Deviaphan,
I've tried on my Mac M1. Versus works with OBS Studio, that is the good new.
However, When I try to install the plugin for Elgato Stream Deck, it says that the plugin works only for Windows.
Do you think it's possible to make a Stream deck version available for also MacOS please ?
An idea of feature for a futur version:
My database has many players name and flags. Choosing a player sometime is not easy because you have to scroll down and sometime name could start with special characters. Could be nice to have a seach field in order to easy find and select player name un score board.
It works perfectly now !
You should publish on Stream deck market.
Many thanks!
It looks like there is some problem with fonts. Apparently, the required font is not included with MacOS. It will be necessary to either integrate the font or replace it with a cross-platform one. Thanks for writing about the results!
I have a question regarding the API functionality.
Our community is using a self developed tournament management software, where players can enter the data of their match via a smartphone app. The app pushes this data to the tournament management software. The data includes:
- Winner of the toss (determines which player has first turn)
- The current turn (player 1 or 2)
- Scored for player 1 and 2
The data in the management software also includes:
- Player names (2x)
- Other organizational data, e.g. table number
The goal is to push some of this data to Versus for display in OBS.
Is that possible? I checked the howto.pdf file in the Versus archive, is there additional information regarding API access?
Thanks and BR.
Hi! At the moment, you can only change the players' score remotely. In the next version, the API will be redesigned for full control, but I can't name the release date. This year there was no time at all, I hope to release a big update next year. I didn't make a description of current API version, because it was only for the StreamDeck plugin.
OK, thanks for the quick response!
Best.
I was looking for a way to dock your tool into OBS, when I found this (quite) new plugin:
I tried to integrate Versus into OBS with it, but failed... :-D
I notified the author of the app about this.
Do you know of any other possibilities to integrate your tool into OBS?
Thanks,
Oliver
Thanks,
Oliver
one way is to configure a user defined browser dock using localhost:9090/controls.html.
Unfortunately, I cannot control the text and logo fields with this, I use them for other information.
With respect to the Window Dock plugin: It seems the plugin has problems with apps that have special characters in their task name.
I noticed this plugin has a ® in there, maybe there is there a quick way to remove this ?
Best.
