Resource icon
Window Dock 1.0.0
OVERKLOC
OVERKLOC submitted a new resource:
Window Dock - Dock Any Desktop Window into OBS – Expand Beyond Browser Sources with Desktop Window Integration
Embed windows from your desktop into OBS to save on screen real estate and keep everything related to stream monitoring in one place.
View attachment 107531View attachment 107532
Installation (Windows Only)
  • Unzip the download in the OBS folder for example:
    C:\Program Files\obs-studio\
  • Start OBS Studio 64 bit
  • Attach, detach, and manage window...
Hey Overloc - this is an awesome add on.
I did discover a fault in when I docked streamerbot chat it appear to destroy the host process's (streamerbot) interface.
That is to say when it's docked chat work but I can't look at settings in streamer bot or change anything. My settings tabs was almost completely blank for example.
Good to know. I'll try to find some time to look at it when I get a chance.
Hi
I have tried installing this and it shows in the tools menu but then my OBS crashes as soon as i click the menu to open the window docks
this seems very promising and I would like to get this to work with the Versus scoreboard tool for OBS:
When I open Tools -> Custom Window Docks the scoreboard app is listed, and I can select it.
But when I want to activate the dock, I just get "Unable to locate desktop window..." although the scoreboard app is up and running.
Pressing "Capture Window" has no effect.
Thanks, best.
OBS Crashes when I click on Custom Window Dock but I have high Hopes for this plugin if it works
also if it works it is very slow and takes like 10 seconds to save settings and apply
Nice plugin, it does have an issue though. I have a java application I'm capturing in a dock, and I can't use any keyboard inputs (mouse clicks work fine). All of the text fields become uneditable, it seems like something is swallowing up keyboard key presses.
Is there any news on this appearing on Mac?.
This would be a god send as I am trying to dock a Mac app that controls lighting inside of OBS.
I found the solution: if you make a new blank profile and new blank scene collection you can add all the window docks you want without OBS Studio (not responding) then go back to to the profile and scene collection you use and use them.
Was causing my obs to crash-- dont know if thats because of a new obs version or a conflicting plugin
Kinda like the Application audio capture, there should be an option to target windows of the same .exe, because if I undock to show my application and the window name changes, the window will not redock
