Yami Resized
Yami Resized 2.1
Monsteer
I've installed this theme but a lot of the buttons don't display correctly. Is the download meant to also include a folder? Currently it only comes with Yami Resized.qss
Default Yami works fine for me. I put Yami Resized.qss in %APPDATA%\obs-studio\themes\
Or am I supposed to put it somewhere else?
The default folder for themes is ...\obs-studio\data\obs-studio\themes
You should see the other themes (Acri.qss, Dark.qss, etc.) in this folder.
Oh nice, it's working now. Thanks! I should have looked up the proper folder more closely.
Any plans for a Yami Resized Light version?
Also I do wonder whether it can be made even smaller, as the original System theme is still smaller than Yami Resized.
Perfect! Thanks to you i have included the required version and the installation path in the post.
I can try a version with the same size of the system theme, i'll keep it in mind.
Thank you Ben!
Monsteer updated Yami Resized with a new update entry:
Special fix for Multiple RTMP outputs plugin
  • Special fix for Multiple RTMP outputs plugin
  • Fix for cropped tab buttons
  • Small improvements
Yami style for Media Controls plugin
  • Media controls plugin now have the same style as the Yami theme.
  • Small fixes
Thank you very much for this! I consider this a real improvement even on a large monitor with high resolution. I'd love to see the heights of buttons made even shorter to come closer to the older dark theme.
