Yet Another Audio Duplicator
Yet Another Audio Duplicator 1.1 patch
700hours
700hours submitted a new resource:
Yet Another Audio Duplicator - Duplicate audio from loopback device to auxiliary device with three commands
When using a capture device and working with HDMI audio routing, typically the capture device needs the audio to flow through the HDMI connection. If the idea is to hear the audio from the source device and capture it, an alternative from listening to the device on the output device is duplicating the audio stream. Basically then the source device being...
This is not compatible with newer versions of .NETCore.
In 1.1 patch the framework was changed to .NET Core 3.0.
Also an aside: an audio doubling bug was fixed by resetting the transmission upon each "start" command. This means "stop" is more or less a "quit transmission" command instead of a reset step.
